์ฃผ์š” ์ฝ˜ํ…์ธ ๋กœ ๊ฑด๋„ˆ๋›ฐ๊ธฐ
The LN46A530 has a 46" display, combined with SRS TruSurround XT. The PC input allows this display to double as a 46" computer monitor
What to do about vertical lines ... already changed out t-con board
Hey I have replaced t-con board and ribbon, and still have coloured, vertical lines appearing on screen. What should I check next?
Also, any tests for that particular t-con board to verify it is not defective - tv model number is LN46A530P1FXZC.
Any help is much appreciated!
์ด ์งˆ๋ฌธ์— ๋‹ตํ•˜๊ธฐ ์ €๋„ ๊ฐ™์€ ๋ฌธ์ œ๊ฐ€ ์žˆ์Šต๋‹ˆ๋‹ค
์ข‹์€ ์งˆ๋ฌธ์ž…๋‹ˆ๊นŒ?
์ ์ˆ˜ 1
๋Œ“๊ธ€ 1๊ฐœ
Check your ribbon cables going to the screen
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€ 3๊ฐœ
๊ฐ€์žฅ ์œ ์šฉํ•œ ๋‹ต๋ณ€
check the ribbons that go from the tcon to the lcd panel itself, to do that you will probably need to take the bezel off and rub you finger along the ribbons
์ด ๋‹ต๋ณ€์ด ๋„์›€์ด ๋˜์—ˆ๋‚˜์š”?
์ ์ˆ˜ 2
๋Œ“๊ธ€ 2๊ฐœ:
Dan does this mean taking the screen out partially
you shouldnt need to just the plastic bezel around the actual screen
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
B P that will depend on what those lines look like. Post an image of what your screen displays with your question. Use this guide ๊ธฐ์กด ์งˆ๋ฌธ์— ์ด๋ฏธ์ง€ ์ถ”๊ฐ€ํ•˜๊ธฐ for that. Besides the T-con board you can get lines from a bad main board as well as TAB failure. Tab failure is where the bonding of the ribbon cables from the driver board to the inside of the panel have failed.
Update (12/05/2017)
Looking at the image this does not appear a T-con board issue. Main board, possibly the panel driver or even the power board. Start by replacing the main board
์ ์ˆ˜ 2
๋Œ“๊ธ€ 1๊ฐœ:
I agree.. this is what was meant in my post regarding the LCD screen may need to be replaced
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
If the LCD is bad (could have caused T-Con to go out) there is not much you can do except replaced the LCD. A bad T-Con board usually shows as a blank screen with sound and some back lights. โ€ฆ A lcd with lines is usally the LCD screen it self. By looking and ready your postโ€ฆ Iโ€™d consider replacing the LCD.
์ ์ˆ˜ 0
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€์„ ์ถ”๊ฐ€ํ•˜์„ธ์š”
B P ์˜์›ํžˆ ๊ฐ์‚ฌํ•  ๊ฒƒ์ž…๋‹ˆ๋‹ค.
์กฐํšŒ ํ†ต๊ณ„:
์ง€๋‚œ 24์‹œ๊ฐ„: 1
์ง€๋‚œ 7์ผ: 10
์ง€๋‚œ 30์ผ: 27
์ „์ฒด ์‹œ๊ฐ„: 9,147
