주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
troubles with home button after changing front panel
Hi all,
This is my first fixing with ifixit.
I have an old Iphone 5 with brocken screen so I bought the front panel from the website together with tools.
Everything works good untill I switch the phone on after the replacement. The home button doesn't work.
As the reassembly instructions are only the step back , I was really wondering if I had done the right things.
How do I ensure that the 2 golden dots are aligned with their counterparts on the back panel?
How do you ensure that the golden dots are "reglued" correctly?
Thanks for your help
B
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Have you followed this specific guide?
Check out Step 23 to see how the pads should be placed. There should be sufficient residual adhesive to allow them to properly stick to the new screen.
I would also check Step 12 and look at the bottom-center of the image. Those gold "fingers" are what make contact with the pads. Make sure they are bent ini such a way that they can contact the pads. Be careful as they can break easily.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Baptiste Le Sueur 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 45
