주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 15-7569은 터치스크린 기능을 갖춘 15인치 노트북입니다. 2015년 Dell에서 출시한 2-in-1 하이브리드 노트북 겸 태블릿입니다.
Spots on my computer screen.
So my laptop has spots that appear in the screen around the edges and corners. The spots are a Orange-ish yellow-ish tint to it and will often appear in different areas.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
@cmelopel post some images of what your screen shows with your question. That way we can see what you see. 기존 질문에 이미지 추가하기
의 공유
댓글 달기
답변 1개
가장 유용한 답변
I think it has to do with the frame putting pressure on the cable that connects the LCD to the board of your computer. Do they appear in different places if you hold a different spot when you open your laptop? I think its from when you open your laptop. I had a Toshiba that had the slide lock right in the center. Over time, I developed lines right through my screen in that area. I noticed if I pushed on that spot and kinda wiggled, it make them either worse or better. Does moving your screen, or putting pressure in certain spots make it better or worse?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Christopher Melo-Pelaez 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 6
지난 30일: 13
전체 시간: 413
