주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GSM 4G LTE 셀룰러 네트워킹(AT&T)을 지원하고 16, 32, 64 또는 128 GB의 저장 용량으로 제공되는 4세대 Apple iPad의 수리 안내서, 분해 및 문제해결 정보입니다. 2012년 11월에 출시되었습니다. 모델 번호 A1459로 식별됩니다.
Proximity sensor fail after screen replacement?
Hi,
I recently replaced a digitiser and LCD in an iPad 4. The repair was successful - until a month later the client has came back to me and there's no display, it's responsive to iTunes so it is not dead. I can only think of the proximity sensor? It's just a black screen.
Where abouts is the proximity sensor located and is there anyway of just disabling it so the display can work again?
Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
It's not the proximity sensor.
Have you tried holding home and power button for 15 seconds and try turning on the iPad on again?
If you see apple logo again then nothing to worry about, just tell the customer if it happens again just hold home + power button for 10 seconds. Explain to them that the software crashed.
I would say loose LCD display cable on the iPad 4 but highly unlikely as it uses a black flex cable that is taped on.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
I replaced the LCD after checking the cable was connected properly, and still a black screen. I've factory reset it and still hasn't resolved it..
의
Looks like the iPad has a board level issue most likely in the backlight circuit area. Micro-soldering work needs to be done on it in order to fix the problem.
The value of an iPad 4 might not make it worth fixing depending on the customer. (e.g blown backlight filter)
의
댓글 달기
답변을 추가하세요
Jack Leslie 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 22
전체 시간: 578
