주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Huawei의 2016년 플래그십 스마트폰입니다. 유니바디 케이스와 Leica와 협력하여 개발한 듀얼 후면 카메라 시스템이 특징입니다. 32/64 GB 저장 용량 옵션과 6가지 색상 마감으로 제공됩니다. 모델 번호는 EVA-L29, EVA-L19, EVA-L09입니다.
Camera App and Flashlight Not Working
I'd dropped my Huawei P9 a few months ago and the screen broke pretty badly. I finally ordered a LED+Digitizer from iFixit and got my screen replaced just last week. But now, when I try to open my camera app, the black rectangle animation of the app opening just barely reaches the edges of my screen before the app crashes/force closes. I've tried seeing if the camera will work on other apps, but it will force close Instagram and just gives me a black screen on Messenger.
I went back to the guy who helped me replace my screen. He opened my phone up again to check the camera pins and he said the camera pins were fine. He even connected my phone to the old screen again to see if there might've been an issue there(?) but the camera app and flashlight were still not working. He insists that it's a software issue and that I need to factory reset my phone, which I'm all but ready to do, but I wanted to reach out into the community and see if anybody had other ideas about what the issue might be.
It's a Huawei P9 EVA-L09. My camera and flashlight were working absolutely fine before the screen replacement. (Everything was still working smoothly except for the screen, really.)
Thanks in advance for any help!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 12개
I have a P9 Plus and I have exactly the same problem. Even the trouble shooting part is exactly the same as my experience. Does any one know how to get t a diagnostic tool to test the hardware on Huawei Phones. Please help.
의 공유
I have the same problem on an P9 EVA-L09 with software version EVA-L09C432B398, The back camera works but as soon as you switch to the front camera, nothing works anymore and the app crashes. You have to force stop and reboot in order to get back camera functionality again, otherwise the app always crashes ?? This happened after a battery replacement (I have tested with a new front camera, it didn't help).
I'd be grateful for any sort of help!!
EDIT: Flash still works for me, but i first had to activate it from the lock screen. (it was blacked out in the quick toggles in the notification bar)
의 공유
I have the same issue. Camera app is showing a black screen for a second before fading away. I installed open camera, now selfie camera is not working. But I can use back camera. I factory reseted the phone, but still have the same issue!
의 공유
i also have similar problem recently. Is there anything can be done to solve this problem?
의 공유
I have same problems, when i try to open camera, snapchat, is screen black for one second and than throw me to backgound... this happens me after bettery change...
thanks for answers!
의 공유
댓글 7개 더보기
댓글 달기
답변 8개
가장 유용한 답변
Hey, you could indeed try to reset it. But I don't think that will help. While replacing the lcd did you disconnect the camera?
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I to have this issue i repaire phones as a living and automatically disconnect battery but customer came back saying camera not working could it be afault in the lcd ?
의 공유
댓글 달기
I solved the problem of camera and flashlight missing on my Huwei P9. It was due to the loose connector that holds both devices pins inside the top part of the phone. It can happen after opening the phone to replace other parts, because you sometimes need to take away and put back this connection. It can also happen whent the phone falls, the connector gets loose. So you must ask for opening and attach again this connection. In my case we needed to do it several times before having it tight enough, otherwhy it would happen again after a few weeks. Luckily this part is easy to access.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I have the same problem by the p30 pro. I have check the connectors of the camera's and reinsert these. Do you know a other solution?
Thanks in advance
의 공유
댓글 달기
Let the battery discharge completely until the phone turns off. Charge the phone for five minutes. Then turn it on and test the camera. That worked for me. You do not need Hard reset or anything complicated
이 답변이 도움이 되었나요?
점수 0
댓글 달기
https://www.techjunkie.com/how-to-fix-ca...
“Restart the Huawei P9 (hold the “Power” button and the “Home” button at the same time for 7 seconds until the phone turns off and vibrates).
Go to Settings, open the Application manager and then go to the Camera app. Select on Force stop, clear data and clear cache. Restart your phone again”.
That worked for me. Good luck.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I just installed Open Camera and it is giving me the message that says “failed to open camera. Camera may be in use by another application? ID:0”
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Just disconnected the main rear camera and the front facing camera is now working! I’ll see if I can source a rear camera.
의 공유
No open .come menu
의 공유
댓글 달기
Nicou posted earlier that it might be an issue with the pins. That would make me think it’s a grounding issue where the pins contact the copper strips on the back side of the motherboard. I’ll try bending them out and cleaning the copper when I open it up again. I did find a rear camera on Amazon for the P20 and hopefully will have it by Friday.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It's because of electricity in the board.. try remove battery and after a minute connect it again. It will fix.. good luck.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Selfy camera no open...torch no open
Update (11/30/24)
Selfy camera ,torch no on
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sally Zhang 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 28
전체 시간: 15,032
