주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Error 4013 iPhone 6
The iTunes will stage, 'waiting for iPhone', and then into, 'preparing software for iPhone'. I will then go back to 'waiting for iPhone' and crash, ending in error 4013! It is otherwise in a constant loop. I cannot access and settings!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 16
댓글 3개
1. Do a Factory Reset of your iPhone Device
2. Clear Cookies, Cache, and History from your iPhone Device
3. Reset your iPhone Device
4. Use RecoveryTool
http://bit.do/exGXL
Will this get rid of that code and make phone work with no further issues or once the error has already popped up are you screwed ?
Iphone 6 getting same error 4013. I just replaced broken screen and display ok but since getting error 4013. new part in good condition as well try almost 4 computers still same! Only thing diff is miss the metal part above the display cables. Can be cause the 4013 issue ?Appricate your help! Thank you
댓글 달기
답변 7개
선택된 답변
Error 4013 is a board level issue that only people that have micro-soldering skills can fix.
This may involve one or more of the following:
- Removing the NAND memory chip and reprogramming it
- Diagnosing and fixing the power circuit(s) going to the baseband or processor.
해당 답변은 도움이 되었습니까?
점수 11
댓글 1개:
Check the condition of CPU power supply or components on power supply rails. Or check if the CPU is pseudo soldered or damaged.
Here we have a repair guide for fixing iPhone 7 error code 4013 for your reference: https://blog.rewatechnology.com/how-to-f...
댓글 달기
This error could be due to multiple issues, In short the error is a connection error that is telling you that there is a communication issue between the device and the PC. Here are some solution
  1. Try a different cable, preferably an official Apple Lightning cable
  2. Try a different USB port
  3. Clean out the Lightning port, lint is sometimes in there not allowing a good connection, use a pick to clean it up
  4. Try a new charging port, sometimes these port get worn and need replacement. This could be causing that error
If all of these are tried and it still doesn't work unfortunately you have a motherboard issue which unfortunately would need a motherboard repair which most often is not cost effective. Hope this helps, best of hopes!
iFixit iPhone 6 Lightning Connector Guide
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Using Joyoshare UltFix can repair your iPhone error 4013 without data loss. I have tried myself.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Download Reiboot on your PC and connect iphone to pc. Then click on “Exit Recovery Mode”. Thats it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
but my iphone 6 ill still error 4013 again
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
did you try Reiboot?
댓글 달기
i got same issue always Stuck on iTunes. Then Imyfone they help me out repair it and now working fine.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
1. Connect your iPhone 6 to the computer. Open up the iTunes utility.
2. Make a backup of all your user data or it will be erased.
3. Upon finishing the backup, disconnect your iPhone and turn off iTunes.
4. Open the Recovery Mode by holding the Power and the Home button at the same time until the black screen appears.
5. Now open iTunes from the PC.
6. Connect your iPhone, iTunes will indicate “Device is connected in the recovery mode”
7. Now follow the simple instructions and restore your device. Result in; your data will be wiped out.
8. Restore your data from the backup you made earlier.
Greetings,
Peter
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Idiot phone never on stuck on apple logo how to backup data u moron
@janigamer Please, no name calling. Antonios went to the trouble of trying to help and it does no one any good to discourage them and make sure they never want to try helping someone again.
Yes, you can certainly point out that being stuck on the Apple logo means the phone cannot be backed up, but the rest of the information about putting the phone into recovery mode could conceivably help someone, but calling them a moron isn't called for.
댓글 달기
귀하의 답변을 추가하세요
Cody Potato 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 32
전체 시간: 34,757
