주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo ThinkPad X220. 2011년 4월에 출시된 비즈니스 노트북입니다. 이 12.5인치 노트북은 2.1GHz Intel Core i3 프로세서부터 최대 2.7GHz Intel Core i7-2640M 프로세서 및 Intel 통합 그래픽까지 다양한 사양으로 구성할 수 있습니다.
How to Reset Bios Password?
Hi All,
I have Lenovo X201i and have supervisor password on it. I want to reset this password.
I dont know the password and without password it is just useless.
Please give me a solution.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
You just need 4 steps to do it. It is easy in this guide, https://www.isunshare.com/blog/how-to-re...
의 공유
generic answer. The x201 has a more elaborated password mechanism *stored in a separate nonvolatile chip* so this answer is useless
의 공유
댓글 달기
답변 4개
선택된 해법
There are 2 ways to do this.
1) purchase a password removal service from Ebay
2) purchase a new BIOS chip. You would then locate and desolder the BIOS chip from the laptop then solder the new one in its place.
https://www.ebay.com/sch/i.html?_from=R4...
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
As i know the way 1 will be easier, the login password or admin password can be removed from your Lenovo ,https://www.recoverywindowspassword.com/... , It has nothing to do with the BIOS.
의 공유
댓글 달기
가장 유용한 답변
I think my x201 has BIOS firmware but your X201i may well be UEFI. In which case there are software tools you can use, which we refer to in the Restart Wiki - see https://therestartproject.org/wiki/UEFI_...
If it's BIOS there should be some way of resetting it - most likely a pair of solder pads on the motherboard that you have to short together. On some laptops I recovered a while back it was a bit tricky but worked in the end. Hopefully, MrGoogle will be able to help you if you pester him hard enough, if not yandex.ru or baidu.cn tend to have less scruples about sharing manufacturers' data.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
I have searched a lot and tried shorting bios chip but no result.
의 공유
That won't work. You cannot short it. You have to replace the BIOS chip or have a service unlock it for you. The new UEFI has some sort of secondary security. Blame it on Snowden.
의 공유
댓글 달기
hi sir how are you
i need halp for my lenovo t440p laptop in bios how to unlock plesse tell me thanks
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Been there - done that with my thinkpad x230. To remove supervisor password - just short circuit SDA and SCL legs on the EEPROM chip before entering the BIOS on startup Chip wherebouts: http://www.ja.axxs.net/x220.htm Instructions to follow: https://www.youtube.com/watch?v=ANZjUPUY...
Some disadvantages of locked BIOS:
  • you can't change boot device
  • you are not able to enable Virtualization abilities of the CPU
  • you couldn't turn off Anti-Theft and other security features
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Where are the pins in a lenovo x230?
의 공유
댓글 달기
답변을 추가하세요
Ahmed Sheraz 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 62
전체 시간: 17,350
