주요 콘텐츠로 건너뛰기
2016년 3월 Samsung에서 출시되었습니다. 모델 SM-G930V.
425 질문 전체 보기
Finding IMEI with FRP lock
hey guys.
Im looking to get the IMEI off of a board i got delivered. but its FRP locked. there are no identifiers on the board itself, and the dial code *#06# doesnt work because emergency caller wont allow it.
Am i missing something as to where that should be recorded? i know iphones have the "i" at the bottom corner, but samsung doesnt appear to have it.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 7
댓글 달기
답변 3개
가장 유용한 답변
Does Download mode or Recovery mode show the IMEI?
Download Mode may show through adb?
해당 답변은 도움이 되었습니까?
점수 2
댓글 7개:
neither of them show the imei. Im currently installing ADB to run through the last suggestion. while im doing that, do you have the command i would use to pull the IMEI through adb?
adb shell dumpsys iphonesubinfo
i get No device/Emulator found When i try to connect. i Have Google USB drivers installed in my SDK manager.
Removed comment.
댓글 2개 더보기
댓글 달기
press volume up, power and home buttons all at same time. While holding down all 3 buttons the screen will start to flash and immediately let up on buttons and hit volume down and the IMEI, SKU and SN will appear on the screen.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Should the phone be off or on ?
댓글 달기
if the battery cover is original it will have the imei at the bottom, hard to see i suggest some kind of led light to shine against it
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Scott 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 22
30일 전: 76
전체 시간: 11,009
