주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 3월 삼성전자에서 출시했습니다. 모델 번호 SM-G930, 버전: G930F (글로벌); G930FD (글로벌, 동남아시아); G930W8 (캐나다).
Finding IMEI with FRP lock
hey guys.
Im looking to get the IMEI off of a board i got delivered. but its FRP locked. there are no identifiers on the board itself, and the dial code *#06# doesnt work because emergency caller wont allow it.
Am i missing something as to where that should be recorded? i know iphones have the "i" at the bottom corner, but samsung doesnt appear to have it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 10
댓글 1개
this is lwky a good question, I have the same problem, my best friend gave me her old Samsung Galaxy s7, and she kinda just gave me the password and got tfo so I looked up a ton of shi and the FRP lock is genuinely killing my soul right nowwwww.
의
댓글 달기
답변 3개
가장 유용한 답변
Does Download mode or Recovery mode show the IMEI?
Download Mode may show through adb?
이 답변이 도움이 되었나요?
점수 3
댓글 7개:
neither of them show the imei. Im currently installing ADB to run through the last suggestion. while im doing that, do you have the command i would use to pull the IMEI through adb?
의
adb shell dumpsys iphonesubinfo
의
i get No device/Emulator found When i try to connect. i Have Google USB drivers installed in my SDK manager.
의
Removed comment.
의
댓글 2개 더보기
댓글 달기
press volume up, power and home buttons all at same time. While holding down all 3 buttons the screen will start to flash and immediately let up on buttons and hit volume down and the IMEI, SKU and SN will appear on the screen.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Should the phone be off or on ?
의
댓글 달기
if the battery cover is original it will have the imei at the bottom, hard to see i suggest some kind of led light to shine against it
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Scott 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 47
All Time: 12,938
