주요 콘텐츠로 건너뛰기
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
205 질문 전체 보기
Black screen and blue light then turns off
So i recently dropped my 2DS, i picked it back up and tried turning it on. It turned on, i know that because the blue light goes on, but then the screens stay off, then after a few seconds the device turns back off. Also while it turns off u faintly hear the speaker make a noise and then it turns off ,just like the device itself.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 1개
가장 유용한 답변
Hi!
Is the console rattling if you shake it a little (that would indicate that a component broke off the main board)?
If not, then I'd suggest that you take it apart using this guide, then rebuild it, to make sure that there are not loose ribbon cables and connections.
If that does not work, I'd look into a screen replacement.
해당 답변은 도움이 되었습니까?
점수 5
댓글 2개:
yeah something is rattling now that say that, i just noticed.
Alright, now that we know that, we can point you in a right(er) direction. Start by tearing the console down. Find the broken component. Take a picture and attach it to your query.
댓글 달기
귀하의 답변을 추가하세요
Arjen de Aldrey 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 8
전체 시간: 6,157
