주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
D1760-2 DECT 6.0 Cordless Home phone with caller ID.
How do I activate/program answering facility
How do I activate/program the answering facility
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
When someone calls and I do not answer they get a message my answering machine is not set up. How do I set it up properly in order to activate it?
Hi @paulette ,
Please confirm the make and model number of your phone?
댓글 달기
답변 1개
선택된 해법
Hi,
Try the following:
1. Press the Message/Mute button
2. Press 8 or the talk button
3. Say your message
4. When finished speaking your greeting, press 8 or End button.
You should hear a confirmation tone followed by the greeting you just recorded.
For Record Time:
Press Menu & Select "Answ. Setup" then select "Record Time"
Scroll to the desired setting (1min, 4min, or Announce Only).
Press the OK soft key or Select (depending on model). You will hear a confirmation tone.
For Ring Time:
Press Menu & Select "Answ. Setup" then select "Ring Time"
2) Scroll to the desired setting (2, 4, 6, or Toll Saver).
3) Press the OK soft key or Select (depending on model). You will hear a confirma
Update (12/31/2017)
Hi,
Not sure of this, but do you get a "delete" option if you press the End button again after the message has been replayed following the recording of the answer message?
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks for you're assistance. I need to erase a previous message as both ( new and old)messages are coming thru at the same time.
Michael
댓글 달기
답변을 추가하세요
Michael Chircop 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 18
전체 시간: 1,432
