주요 콘텐츠로 건너뛰기
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
99 질문 전체 보기
unable to activate touch id on this iPad after screen replacement
Hello everyone,
I had a broken LCD & touch screen in my iPad 5th generation, i purchased the LCD and the screen (Item code: IF128-018-5) i replaced all parts and all looks great..! then when i started my iPad it showed me this msg: unable to activate touch id on this iPad.
So the touch ID is not working and the home button as well, not just the sensor! Please advice.
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Hi, I have the same problem. The pre-installed home button does not work and if I connect it when the iPad is on, Siri starts.
the old home button works but not touch id, my iPad showed me this message: impossible to activate the touch ID on this iPad.
Please advice
Thanks
댓글 달기
답변 4개
선택된 답변
Actually, if you installed IF128-018-5, then that digitizer came with a Home Button pre-installed. That means the Touch ID will not work. You need to transfer over the original Home Button from your cracked display if you want touchID functions. See this guide.
You have to be careful not to tear the flex cable on the HB otherwise you will lose one or both functions.
해당 답변은 도움이 되었습니까?
점수 5
댓글 2개:
I did not see that coming! i threw the cracked screen away before i purchased the spare part. in this case what can i do?
There's nothing you can do to regain TouchID other than have it repaired by Apple.
댓글 달기
You probably accidentally broke the home button flex. If it's broken, Touch ID and home button won't work. You will probably need to replace the home button assembly, unfortunately this means that you lose Touch ID permanently since it's paired with the original home button and motherboard.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
i have not used my ipad for last six months it is fully charged but key pad will not work i am barred out. is there way to activate my touch screen
댓글 달기
What if i delete my finger touch setting can i redo the with a new home button if I deleted and disable touch before i replace my screen the first time also can i just blow away my entire iPad Air 2 and start over with either a new home Britton or my old one
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
No. The home button is programmed with the motherboard, there is nothing you can do.
댓글 달기
unable to use touch screen key pad locked. cannot enter pin
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dabbor 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 7
7일 전: 52
30일 전: 226
전체 시간: 14,598
