주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GSM 4G LTE 셀룰러 네트워킹(AT&T)을 지원하고 16, 32, 64 또는 128 GB의 저장 용량으로 제공되는 4세대 Apple iPad의 수리 안내서, 분해 및 문제해결 정보입니다. 2012년 11월에 출시되었습니다. 모델 번호 A1459로 식별됩니다.
New digitizer not functioning?
Had a particularly frustrating screen replacement yesterday with a digitizer screen that fracture and splintered with every successive pry. Finally managed to get everything apart and cleaned up with no further damage to internal components (VERY surprised that the instructions did not specifically call out disconnecting the battery BTW). Reassembled everything and went to test prior to sealing the new screen down only to find that it's not functioning. The home button works fine and the LCD has crystal clear picture, but there's no touch input whatsoever. Any chance we got a bad digitizer? Recommendations?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Final follow-up on this. The original digitizer was sent back before I could retest it, but I had the exact same issue on the replacement. I found that the white lines on the digitizer cable need to be inserted further into the connector (until they disappear into the connector). Unlike the LCD screen connector where the lines are still showing.
의
댓글 달기
답변 1개
선택된 해법
Probably just a bad digitizer, you did fully insert the digitizer ribbon cable into the port and clipped the two connectors down right?
The battery does not need to be disconnected for digitizer replacements on iPad 2, 3 and 4 because the LCD does not need to be unplugged during a digitizer replacement, it simply just needs to be moved out of the way.
Note to others, always test the touch screen and home button before fully installing the digitizer as you may just crack the glass when removing it again.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Eric Montgomery 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 365
