주요 콘텐츠로 건너뛰기
Model M7886 / 450 MHz 또는 500 MHz PowerPC 7400/7410 (G4) 프로세서
Why does my Cube take for ever to power on
Hi guys,
so recently I‘ve noticed that my Cube takes really long to turn on. Like minutes. Also when I put the cable into the outlet it takes a couple of minutes for the green led on the bottom to turn on. Does anybody have an idea what could cause the problem?
Also I might have to note that I live in Germany so we have 230V mains voltage, if there is any known defect in European Cubes.
Thanks for your help!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@lambda possibly running into issues with either your power brick or your DC-DC board. You do want to check the output of those with a meter and see. Use these guides Power Mac G4 Cube and teardown to check things over.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
--- 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 100
