주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년에 Google에서 출시한 2세대 크롬북.
Battery Replacement for Chromebook
Please let me know how I can change my Chromebook Pixel 2 (2015) battery
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
If you heat up the battery enough to loosen the glue, the battery just starts crinkling up. LOL.
Heat up one side first and pry up the end battery. Once that is up, you can put your heat gun underneath a 2" putty knife as you pry it off.
Aside from the glue, it's an easy job. And the batter is unblocked by any parts.
의 공유
댓글 달기
답변 2개
가장 유용한 답변
Buy a Li-ion Genuine Battery For C1551B 7.6V 70.6Wh 9295mAh on Ebay and replace the battery.
I’ve successfully changed my Pixel’s battery: Open Pixel according to iFixit description, unplug the old battery, use a hot air gun to soften the sticky pads and remove and replace it with the new battery.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
  1. follow ifixit’s guide to remove the back panel.
  2. unplug the battery (there is only one cable, unplugging it is easy)
  3. remove the old battery. This is the hardest step, the battery is glued and removing it is practically impossible without destroying - or at least without twisting and deforming - the old battery. Proceed carefully, a heat gun helps. Also to pry the old pieces off I found that a kitchen butter knife works best. I tried a plastic spudger at first and it broke. Be careful especially when you remove the MIDDLE TWO pieces of the battery (there are six in total, and it’s best to start from the sides and work your way towards the middle). The middle two pieces are glued to a metal plate that sits under the mousepad, and if you’re not careful it’s very easy to get that plate deformed and twisted. Just use a heat gun and go slow.
  4. finally putting the new battery on is straightforward. The batter should have protective film covers on both sides. First remove the protective film cover on the side of the adhesives. Place the battery in its place, press, and only then remove the protective film cover now facing you.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Hridai Krishna 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 15
전체 시간: 1,976
