주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kia Optima는 2000년부터 기아자동차에서 생산한 중형 승용차로, 전 세계에서 다양한 이름으로 판매되었습니다. 1세대 모델(2001-2005)은 대체로 Optima라는 이름으로 판매되었으나, 2002년부터 유럽과 캐나다에서 판매가 시작될 때는 Kia Magentis라는 이름이 사용되었습니다.
Shift solenoid A location
I got the code p0750 after driving and the car slipped down to 3rd gear. It wouldn't shift back to 2nd or 4th until I turned it off and started it back up. It says Shift solenoid A, and I am wondering where on the transmission it is located and how to replace it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
It will either be inside or on the side of the transmission.
First thing to do is clear the code and drive it again and see if the code comes back on. If not yay... not really. If it does (or doesn't) then get yourself some new Transmission fluid, and a filter kit that should have the gasket in it.
Drain the old fluid, drop the transmission pan, then inspect pan for debris. Metal is generally not a good sign.
Unbolt the old filter, bolt on new filter. Remove old gasket, gently clean gasket surfaces using wood or plastic. put on the new gasket, replace pan. Do up bolts and torque down.
Refill trans with correct amount of fluid. Erase code and drive. If your code goes away, yay, good this time. If not, it is time to physically check the solenoid.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Also check here for more information https://www.obd-codes.com/p0750
Okau thanks I'll be sure to do that and let you know how it goes
댓글 달기
답변을 추가하세요
Kiyomi McKinley 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 5
전체 시간: 1,919
