주요 콘텐츠로 건너뛰기
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 질문 전체 보기
Replace jack/hold switch with 1 from iPod classic
Hi all,
A short while ago I bought an iPod Video 5.5 80GB, but unfortunately the jack connector already broke (music is playing through 1 ear). I've got a spare iPod classic 160gb 7th gen. Would it be possible to replace the iPod video's jack/hold switch with the one from the Classic?
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
@jeltev Yes they are interchangeable. The headphone jack/hold switch, hard drive cable, and hard drive (from the 5th gen to 6th gen but not vice versa)are compatible. Everything else is not.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Thanks for your reply, that's good news! Not the best time for me to spend money on parts... Will give the repair a try today
Did the replacement today, and it works like a charm! However, I found that placing the iPod Video jack/hold on the iPod Classic is not that easy as vice versa. Tried to fit it for a few mins, but it seems to be a bit too large for the Classic. Needs some puzzling and patience to make it work, I guess.
댓글 달기
Looks like it's a different part for the two iPods, but I think you can buy one from these guys.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks for your reply!
댓글 달기
If haven't already figured it out yet, you have a 5.5 80gb that is a thick case model trying to replace a hold/jack ribbon from a 7th gen thats thin case model, thats why it doesn't fit right , maybe try using the back case of the 7th
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jelte 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 365
