My phone flipped into a soapy water
I have the same problem, my phone flipped into a soapy water, after doing all, the phone get hot and hang periodically .. what can I do
좋은 질문 입니까?
좋은 질문 입니까?
Uzoma Oranebo (Bossuhzi) your question was converted from an answer to someones question. We need to get more details from you. Let us know the make and model of your phone. Also, let us know what you did after the phone fell into the water and how log this has been.
I'd suggest you start treating it like any other water damaged device. The very first thing you want to do is to not try to restart the phone. This may further damage your phone. The next thing to do is to clean it. Disassemble your phone using these guides Remove all EMI shields from your phone, then clean it with +90% isopropyl alcohol. Follow this guide, and even so it was written for an Apple iPhone 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best way to clean it would of course be through an ultrasonic cleaner, so you may consider a professional service . Once all this is done, reassemble your phone and reevaluate.
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 3
30일 전: 9
전체 시간: 1,320
