주요 콘텐츠로 건너뛰기
다양한 TV 브랜드 및 스타일 안내서 및 지원.
9059 질문 전체 보기
Disassembly and Repair Philips 37pfl9604h/12 Black and negative screen
Could someone help me with pictures of disassembly of the Philips 37pfl9604h/12. Also if you have to remove the footh first and how.
Problem is:
The screen is at the left side normal but on the right side slow, and negative, and black.
Questions:
How do i disassembly this tv
Could anyone tell me which part it could be? I heard already things like the ribbon cable, the TCon, or the AUO
Could anyone tell me where i can buy this parts, of let it repair if its too small work or soldering work?
Thanx in advance
I thought you have to take of the footh first to disassembly the tv, thats why i asked that, if it’s possibly without , then also good:-)
Hereby the pictures
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
@ti080 I am a bit confused by your question. "to remove the footh first and how." referring to the stand? "The screen is at the left side normal but on the right side slow, and negative, and black." can you post some images of what that looks like with your question? That way we can see what you see. Use this guide 기존 질문에 이미지 추가하기 for that
Yes it could be all of the parts that you already listed but unless we can see it and you check a few things it is hard to determine.
댓글 달기
답변 1개
가장 유용한 답변
@ti080 looks like you can do this without removing the foot.
Philips is a bit different since most of their service manuals go by chassis number. yours should be a Q549.2e La It'll help us if you could verify this against the label on your TV.
Yes it could be all of the parts that you already listed but unless we can see it, and you check a few things., it is hard to determine.
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
Thanx i put the pictures in the original message, so you can see what sort of screen i see:-( hope you can help me solve the problem. Excuses it took a bit of time, but i was not able to fix or answer
@ti080 looks like some failed backlight LED's. You will have to disassemble the panel and check those out.
You will also have to take a good look at the main board as well. The center darkness looks like a backlight issue. There seems to be some "confusion" on the whole picture. If possible post an image of what the display shows without a menu etc. Right now it appears very "cluttered"
thanx chassisnumber is right as you discribed
How can i see after disassembling if it's the panel? or what it is else?
start with the power board first. make sure that you have the voltages going to the LED's in the panel. If you do then you can pretty much rule in the LED backlight strip.
댓글 달기
귀하의 답변을 추가하세요
tini 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 614
