주요 콘텐츠로 건너뛰기
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
My controller keeps constantly moving to the right in game.
I Just bought a brand new Xbox one S from Best Buy exactly one week ago and I’ve been using it since, but for the past 2 days I have noticed while playing a FPS Game or Forza, my car would slowly turn to the left. Keep in mind this controller is practically new and hasn’t been dropped yet. If you know the problem or have a solution please let me know.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 6개
My original controller from a Xbox one PUBG bundle pack started drifting in run mode so I bought this new controller & it’s great! U have to buy the afterglow prismatic wired controller with 10’ cord & download the PDP app for Xbox one & PC to configure it & change the colors. No need to buy an headset adapter or headset. Saved me 120$. The controller is 28$. My regular Koss Porta Pro headphones (no mic) work great after I downloaded the app. —-> https://www.pdp.com/pdp-app —- > Check out this item at Target https://www.target.com/p/afterglow-gamin...
I had the same problem. Turns out, one of the bumper switches (left bumper) was pressed in and stuck. Once I saw that, I pried it back out, now all is ok again.
This will not Void the warranty. Opening the controler WILL. Best thing is get several Q-Tips and alcohol. Soak in AL then push down in the opening of the JS. Do it several times and getting that alcohol in there. Move your JS back and for a lot. Repeat. Keep doing that for about 4-5 Q-Tips . Remembering to move the JS all around right after the AL goes into the JS. Alcohol evaporates quickly, so let air dry for a little bit and that should help. If it doesn't, but it is better, then do it all over again until it fixes it. If it doesn't help at all you will either need a new controller or to open up the control and cleaning and fixing that way. But, opening the control Voids warranties. So if still under warranty, do not open . If you have bought recently and in under warranty, Go replace it, or call Microsoft to replace it.
"I had the same problem. Turns out, one of the bumper switches (left bumper) was pressed in and stuck. Once I saw that, I pried it back out, now all is ok again." Sorry for the thread revive, (but this is still a current issue) but so strange how the left bumper affects the left joystick! Thx gustep12
how do you connect a wired controller does it turns automatically turns on or not?
댓글 1개 더보기
댓글 달기
답변 3개
선택된 해법
If your Xbox One Wireless Controller has a malfunctioning thumbstick and you cannot properly navigate around your Xbox One, see the Xbox One Wireless Controller Has Malfunctioning Thumbsticks problem page for possible problems and solutions.
This is usually caused by bad analog sticks. In most situations, these controllers are out of warranty and it is easy to recommend the repair, but yours is so new I wouldn't recommend repairing it. In this scenario, contact Microsoft and request a replacement controller. It will likely be new since it doesn't make sense for Microsoft to refurbish them.
If they don't want the broken controller back, the sticks can be replaced without a new bottom board. However, this is time-consuming and should be done in pairs. The reason for this is one stick failing usually means the other stick that still works usually isn't far off from failing as well. Yes, this adds time but you're better off doing them as a pair and fixing the issue for good.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
It's so easy I had this problem and I tried everything but found the answer
Step 1:Unplug the Xbox
Step 2:Take the batteries out of the controller
Step 3:Plug the Xbox back in
Step 4:put the batteries in the remote as soon as it goes on the home screen
And boom!It works for mine so it should for u you hope it works!!
Perfect. Thanks Hollie.
댓글 달기
Try putting your deadzone up
이 답변이 도움이 되었나요?
점수 0
댓글 달기
ALLma analogs keep moving to the left when i press em what could be the prob
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
River Hudon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 66
전체 시간: 117,609
