주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pebble 2는 2016년 9월에 Pebble Technology Corp.에서 출시한 스마트워치이며 원래 Pebble Watch의 개정판입니다.
Is there any replacement for the button covers?
I just had the lower right button cover crack and fall off. Does anybody know of any ways to get a replacement rubber panel?
Has anybody taken the watch apart to see if it's even possible to do this sort of replacement?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 9
댓글 2개
Thanks, Those shapeways links were useful. It took a bit of hand fitting, but those button panels work and now my favorite watch is running again after being idle for far too long.
의
댓글 달기
답변 5개
가장 유용한 답변
I know the original question is an old one, but since a lot of pebble 2s eventually have this problem, here’s a link to my 3D buttons and cases on Shapeways.
https://www.shapeways.com/shops/astosia?...
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Update, if Shapeways’ postage is too high, you can buy buttons from the website now too.
https://favouritehumandesign.com
의
댓글 달기
I had the same problem und found this site, with printable 3D Models:
https://www.thingiverse.com/thing:259955...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
https://www.shapeways.com/product/UAMY5G...
Requires OG Pebble parts, but this may be a good fix.
Update (07/06/2021)
I found this just now, I have two P2HRs that both need new buttons, but I think this may be an easier fix. https://tinyurl.com/k8a5h6na UPDATE (08/05/2021) I bought the version with the battery and glue. It’s a fairly easy transfer. Requires a Soldering Iron and some steady hands, but the fix was worth it! Don’t forget to transfer the microphone seal from your old case to the new one, and use A LOT of glue to get the back sealed back up!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Bonjour, j’ai trouvé plusieurs sites qui vendent des boutons.
https://www.shapeways.com/product/ANHBW4...
https://www.shapeways.com/product/4Q27VC...
https://favouritehumandesign.com/product...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I have resolved with this:
"2 Smart Watch custodia originale in ePaper con pulsanti laterali in gomma e pannello in vetro Gorilla Corning - AliExpress
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Frank Scheers 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 42
전체 시간: 7,574
