주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2000년형 모델로 1999년 말에 재설계된 모델이 출시되면서, Sentra는 마침내 "소형차" 등급으로 올라섰습니다.
RPM Drops to Zero while Driving
RPM Drops to Zero while Driving, releasing X-pedal and car slows down and RPM needle drops to Zero and car starts to Shake/Vibrate.
cleaned throttle body, air flow sensor, changed coil packs, no engine light comes on, changed speed sensor because of misfiring (not changing to 2nd gear).
Didnt service injectors yet, its a bit expensive .
please help me!!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 2개
I own such a car and model This malfunction is for the tps sensor and needs to be re-calibrated and the number is set on the computer number 48 for the automatic car and the number 46 for the vehicle The symptoms of this malfunction are what I mentioned in your question in addition to the violent switching of the gearbox there is a solution to re-calibrate and another solution is the work of Rest For the car computerIt is a temporary and effective solution, and the way to put the key and manage the car key without operating once the Airbag indicator has disappeared. Close the key as soon as you hear a computer click.Repeat the step again - then the third time turn the car engine - now the car computer has been restedطريقة عمل ريست لكمبيوتر السيارة نيسان صني n16
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Une moteur
Il me taire
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Huile moteur
의
댓글 달기
답변을 추가하세요
Nex Gen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 31
전체 시간: 4,509
