주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2001년부터 2004년까지 생산된 Apple 컴퓨터용 17인치 LCD 디스플레이.
Studio Display has gone black.
Power's getting to my M7649 Display, from my G5, but the screen went black a few days ago. I got another M7649 display from a friend and it works fine. Can mine be fixed? is it the inverter? Screen seems black, not dim.
Thanks,
Henry
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
선택된 해법
If you look closely at the display (maybe at an angle) you may be able to see a slight image (like a shadow) if so your backlight has failed and would need replacement.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thanks Wizbang FL! Appreciated.
I plugged it back into the G5, turned off all the lights in the room, fired up the computer and looked for a glimmer of an image, or shadow. Nada. Ziltch. Pure darkness ... except for the 'on' light in the lower right corner of the frame, of course. Holding the screen brightness button brought the button to life, while it was pressed, but nothing more.
So ... I'm now certain that the display is imageless.
Still looking to allow this display to play as it has. If there's a fix, and it won't cost me an arm or leg for the part(s), I'll try it.
Regards,
Henry
의
댓글 달기
가장 유용한 답변
Before replacing the backlight, you might want to take a look at the inverter that controls the backlight. Here's the Apple recall on it and how to fix it: http://macguild.org/display-repair.html
Here's the guide on repairing it from iFixit: Apple Studio Display M7649 인버터 교체
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Henry 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 1,766
