주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
4세대 Nissan Altima(섀시 모델 L32A)는 2006년 4월 12일 뉴욕 국제 오토쇼에서 발표되었습니다. 이 모델은 더 작은 Nissan D 플랫폼을 사용한 첫 번째 차량으로, 새로운 전면 서스펜션과 업그레이드된 후면 서스펜션을 갖추고 있습니다.
2011 Altima Mass Airflow Sensor service engine code
I replaced the mass airflow sensor in my 2011 Altima, but I'm still getting the same service engine code. The sensor was brand new and only in the car for 10 miles when the code came up again.
Please help!
Chanin
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
@chanin what code is it?
의
댓글 달기
답변 3개
가장 유용한 답변
Had this problem for two years, 3 MAF sensors and 4 mechanics later it turns out it was a dirty throttle body that was not letting the air intake to close all the way thus leading to a MAF code. About 700 bucks later its like new again and never had the problem since.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Can you elaborate a bit more?
의
댓글 달기
I tried everything. Replaced the MAF sensor(twice), had the ECM reprogrammed, cleaned the throttle body. The light kept coming back on. My issue was solved by getting the ECM reprogrammed with the original MAF sensor. You can’t get one from a parts store.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I replaced mine at the dealership and light is back on not even 2 years later! Any suggestions on what it could be? I spent $600 replacing it with them and only came with a 1 year warranty!
의
댓글 달기
Tech notes Before replacing the Mass Air Flow (MAF) sensor, try replacing the air filter and cleaning the MAF sensor with low compress air or MAF sensor cleaner. Reset code and drive vehicle. If the code comes back, it may be necessary to replaced the MAF sensor. There is a factory service bulletin for the following Nissan Models: 2011-2012 Nissan Altima Sedan If the P0101 code is set and there are no drivability problems, the factory service bulletin suggests reprogramming the Engine Control Module (ECM) to repair the problem. Bulletin No. NTB12-051d
Read more: https://www.autocodes.com/p0101_2011_nis...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Chanin McKeighen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 43
전체 시간: 20,287
