주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Signet 시리즈는 1950년대 Kodak의 최고급 미국산 35mm 카메라 라인이었습니다. 이 기기는 레인지파인더가 포함된 두 가지 Signet 모델 중 하나이며, 대부분 플라스틱으로 만들어지지 않은 유일한 모델입니다.
double superimposed rangefinder patches problem
When view through viewfinder on kodak signet 35 , the rangefinder patch appear from 2 triangle 70% superimposed but slightly shifted horizontally on left side.I could not discern what would cause one triangle to split into two, though I suspect it's a a misalignment. What area should I be inspecting?.I wait for yours ideas.Thanks.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Your beamsplitter got mis-aligned. Review this IFIXIT guide: Kodak Signet 35 빔스플리터 교체. There should be a couple of small setscrews which has some glue on in to prevent it from shifting. One is to adjust the parallax (up & down) the other the infinity set.
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
where could I buy a new one beam splitter ,because the coating of beam splitter does not exist and when view through viewfinder the triangle from the rangefinder is not longer visible , and i try using a piece of blank 35mm color negative that has been processed which I put behind the beam splitter, and followed these procedures the triangle of beam splitter is visible , but appears as double triangle, probable first triangle is a reflection of 35mm colour negative film procesed , and the second triangle is reflection of beamsplitter glass.What do you think.Thanks
의
This is such an old camera parts will be difficult to find. Maybe you can find a second non-working camera to steal the part from to fix yours.
의
Thank you very much
의
댓글 달기
답변을 추가하세요
Florentin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 43
전체 시간: 831
