주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Vostro는 Dell이 비즈니스용으로 제작한 노트북 제품군입니다. Vostro 1500은 2007년에 출시되었습니다.
My screen died. How do I replace it?
I used this primarily because it had Windows XP. A lot of older games aren’t supported by Windows Vista, Windows 7, Windows 8, etc.
The XP emulator in versions after XP doesn’t’ function well with all games.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
These laptops use a CCFL LCD, which is difficult to find a replacement for today. When you do find them, it's usually a overpriced NOS panel.
If you don't want to give up on this laptop, your best bet is to find a parts laptop with a good LCD that doesn't look heavily worn. If you just buy the screen or screen assembly, it will cost more then a whole new laptop. However, my recommendation is to find a newer model that comes with an XP COA and hopefully has a LED display. XP laptops are usually cheap these days because when XP went EOL, the market was flooded with XP systems. This has essentially made it hard to economically repair XP era laptops that failed without coming close (or exceeding) to the cost of a complete replacement.
The model that I like to replace these machines is the E6410. There's plenty available with an XP license to go around and these can be purchased for relatively cheap. These also use LED screens, so you don't have to worry about LCD replacement cost problems. If you can't find an example with a XP license, you can use the COA from your old laptop and take advantage of downgrade rights, as long as it's an XP Pro license. The catch is you have to get a machine with a 7 Pro license to do this. Home Premium does NOT include downgrade rights.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Thanks for the quick and detailed response.
의 공유
The reason I like the E6410 for cases like yours is that you usually can't find 6420's with a XP license since Dell used downgrade rights on those. By the time the E6420 came out, Windows 7 largely replaced XP/Vista on new systems.
They're not as capable as the 6420, but they have the advantage of being easy to find with XP or 7 Pro (downgrade rights to XP) licenses.
의 공유
댓글 달기
답변을 추가하세요
Major Faversham 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 14
지난 30일: 26
전체 시간: 431
