주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Micromax A110 Canvas 2는 2012년 10월에 발표되었습니다.
How to replace touch screen and display
how to replace touch screen and display
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Battery problm and mobile not charging and not on
의 공유
댓글 달기
답변 1개
I have not repaired one of these, but it looks to be similar to a Galaxy SIII, so maybe use it as a guide.
Just remove the screws from the back, and take the back cover off.
Disconnect the LCD and Digitiser cables if possible.
Lightly heat the front glass, and slide a plastic thin tool (Guitar Pick) around the edges, slowly moving deeper as the screen begins to lift. Once it is off, you should find the LCD should fall out as well.
Clean the glue off, and you should now be able to Install the new LCD and Digitiser. Make sure to remove and protective films from the LCD, and from the inside of the digitiser.
Tape the Digitiser down with provided adhesive and attach any connectors.
Screw the back cover on.
I hope this helps.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sandeep Kumar J 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 22
전체 시간: 593
