주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Moto Z Play(모델 번호 XT1635-02, XT1635-01 및 XT1635-02)는 2016년 9월에 출시된 드로이드(droid) 스마트폰입니다. Moto Z Play는 기기 앞면 상단에 있는 “moto” 로고와 하단에 있는 사각형 홈 버튼으로 쉽게 구분할 수 있습니다.
No touch response after screen replacement
I replaced a screen with a cracked LCD. After replacement touch is unresponsive. During startup, I am prompted to enter my password and after a few seconds I can do so. Once started up, the screen comes on, but I can not unlock the screen. It appears to respond to touch, because the notifications change color when selected, but it does not unlock or prompt me to put in my code to unlock. Help!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Only works now if I'm touching the screen with two fingers
의 공유
hey did you get a solution to this? I am facing the same issue
의 공유
댓글 달기
답변 1개
가장 유용한 답변
Hey Casey!
Incompatible screen. Moto Z Play is a difficult one to find good parts for. Have to make sure the flex configuration is exactly the same as on the original or else it either doesn't work or only works with two fingers like you mentioned.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Great! I am having the exact same issue... Anything that can be done to fix the two finger operation?
When I ordered the LCD screen on eBay, the description said the part was for Moto Z Play XT1635. There was no -01, -02, -03 suffix. So I believed it would work with all of them. I have XT1632-02.
의 공유
댓글 달기
답변을 추가하세요
Casey Reynolds 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 21
전체 시간: 1,495
