주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Why is my tablet screen black?
My tablet was working fine but then suddenly the screen went black. However I let it to charge and and tablet was working normally. All of a sudden the screen went black again and now it is not working but if I press on the volume button I can hear the volume going up and down. So as a result my tablet is fine except for the fact that it is a black screen and can't see was is going on with my tablet. Do any of you have an solution???
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 8
댓글 11개
Can u tell me how I can. Fix I have same problem. Its never been dropped. Looks new. Any suggestions
buy a new tablet is resolved
Having same problem, but works fine when charger is attached.
My tablet is new it is 6 0 7 month old.
Here lately when using my tablet the screen goes black, also when using the touch csreen it doesnt work, what is the problem?
댓글 6개 더보기
댓글 달기
답변 3개
가장 유용한 답변
Have the exact problem right now. Heard of a few options holding down volume button and power for 5 secs and may restart
Also flexing the tablet ever so slightly this worked for me once but back with the same problem.
Let us know If it works for you
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
If flexing the tablet temporarily solves the solution for you then either the LCD display needs to be replaced or the LCD cable just needs to be replugged to logic board again.
Yes I had the battery replaced told this was the problem then it happened again a week later same problem (this is when I flexed it) it worked for one day took it back to the shop And fixed within minutes and this was the same problem
Was I just charged for the battery so they could get some money from me when in reality it was a 5 min job? Hm
How and what is flex
댓글 달기
I hope this answer helps others. I fell asleep watching something on my tablet. The battery alert woke me, so I plugged it in until it was fully charged. When I went to use it the screen was very dark, but everything seemed to work okay. I tried everything, searched through all the settings looking for screen brightness, even deleting some big files in case the memory was full.
Then although it was really hard to see what I was doing, I pulled down the drop down box that has the summary of the functions (time, day and date, wifi icon, location icon, sound icon etc.) and just below those is the screen brightness bar which was at its lowest. As soon as I moved it, the screen lit up as normal. I must have shifted it while asleep.
Lizzie
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Had the same problem with my daughter's Samsung tablet. A black screen but I could hear the tablet "working" so it wasn't totally dead.
Watched this video on YouTube - https://www.youtube.com/watch?v=S-w3fP5b...
As per the video instructions I took the back off the tablet and reconnected the LCD connector. Clipped it back into place and hey presto the Tablet now works and displays normally.
I suspect my daughter may have dropped the unit causing the connector to come loose. Then again it may just work loose over time. Its a fiddly thing to reconnect but you should get it done in 5 mins. Just be careful taking the back off the tablet. Take your time and work your way around the edge slowly.
Hope this helps.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Jeyaseeli Satheesh 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 35
전체 시간: 30,036
