주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
Red indicator over battery iPhone7
Hi guys!
I just bought a defect iphone 7 to inspect and repair (first timer). I've open the phone and I see this "RED indicator" which I guess (know) is some type of water damage. My question is.
Can I fix it? What should I look for?
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
So, about 2 years in the future.
If you have the same problem as this thread holds.
I bought a new logicboard - replaced it and the phone worked perfectly. Till I smashed the screen and had to repair it once again.
댓글 달기
답변 2개
선택된 답변
Water damage is one of the hardest repairs.
it involves completely disassembling the phone,
iPhone 7 Rear Case Replacement
cleaning the water damage using alcohol
Electronics Water Damage
and a new battery.
iPhone 7 Plus 배터리 교체
Good luck!
Rice does not help with water damage!
iPhone 7 Plus 배터리 이미지
안내서
난이도:
운영
30 minutes - 2 hours
iPhone 7 Rear Case 이미지
안내서
난이도:
어려움
2 - 3 hours
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thank you for the answer!
I will take it as the solution. Seems like I have work to do
댓글 달기
It's water damaged phone. See all over phone you can see white spots, that is your water calcium.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Pontus Sennerstam 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 1,243
