Hi @yo_hit_this
The only way to possibly get your game console working correctly again is to clean it properly, by dis-assembling it and using IPA 99%+ to clean all the affected parts as outlined below
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the device's operating design and could damage the components.
First do not turn on your console so as to minimize further damage
Then you need to dis-assemble the device and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is <70% IPA, can contain additivesd and is not as effective. If you do have to use it, check the label to verify the amount of IPA.
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Here is a link to the ifixit teardown guide, which may be of some help.
PlayStation 4 Slim 분해도
Hopefully after you have done all this it might possibly work correctly again.
If this process seems too daunting, take your console to a reputable, professional electronics repair service experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
댓글 8개
How can I get water out of my PS4
Alexandrea Harris 의
my ps4 got water spilt so i dried it it it sparked at first when i lift it while it was off n plugged in i tried to switch it on wat shud i do
thato 의
the spill also affected the tv but the plug
thato 의
I accidentally left ice on my ps4 and overnight it melted and I guess the water went in the ps4 And now it’s not turning on what do I do?
UMessedUp— 의
@UMessedUp—
See the answers below.
jayeff 의
댓글 3개 더보기
