주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Flyer Red는 2014년 12월경 출시된 Hewlett Packard의 노트북입니다.
My computer suddenly turned off and won't turn back on..
I recently bought the HP Flyer Red laptop and it has been working great for about a month until I cut the camera on and it suddenly turned off 2 days ago and won't turn back on. I tried charging it and taking the battery pack off. It came on for a split second and turned back off. I tried it again today while charging it and it came on but went to a dark gray screen with just the mouse pointer showing. What could be the problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi,
What do you mean by "cut the camera on"?
What OS is installed in the laptop?
Have you tried starting the laptop with the battery removed and only the charger connected?
If it starts OK allow it to boot all the way to the Windows desktop, let the HDD activity settle down a bit and then shutdown the laptop in the normal manner.
When it has completely shutdown, switch off the charger and disconnect it from the laptop
Reinsert the battery, reconnect and switch on the charger and then turn on the laptop.
If it starts OK allow it to boot all the way to the Windows desktop.
Check the battery charging status and if the battery is charging allow it to fully charge before switching off the charger and disconnecting it from the laptop.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
My camera turned on and now won't turn off
Hi @Shania Bacchu,
Not quite sure what you mean.
Are you asking about the webcam in your HP Flyer Red PC?
If so what is the exact problem?
What program are you using the camera with etc?
댓글 달기
답변을 추가하세요
krcayson1982 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 1,540
