주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/32/64/128 GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
Home button not working
iPhone se home button not working. Feels normal. Software or hardware problem?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
Can you expand on what is not working; is it only the click function or the TouchID or both? Also, has anything happened to the phone prior to this problem like a drop, a repair attempt or contact with water?
The button may be physically damaged or it may just be disconnected internally. Open up your phone using this guide and take a look inside to see what's going on. Inspect the connection status, the condition of the connectors and the flexes (look for tears).
If the home button is damaged, then you can replace it but you will loose TouchID functions.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Have you had any repairs done before it stopped working? Did you drop it or has there been any water damage? And is it just the home button or is it also the Touch ID?
If you know how to, you can try and replace it and see if it works but I wouldn't recommend you do that because apparently it's pretty hard. You can also pay for someone to replace it or fix it as well.
For the time being, use assistive touch as the home button. Go to Settings > General > Accessibility > Assistive Touch and from there you can toggle the home button on-screen. If you want to screenshot there's also an option for that which you can add on.
Hope I could help and good luck!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Angelo Catch 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 7,523
