주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
G50-30, G50-45, G50-70, G50-80 모델을 포함하며, 기본적인 게이밍 성능을 갖춘 저가형 노트북입니다.
The laptop won't start!
My laptop won't start. It charges well (maybe...the indicator flashes) Although I have clicked the power button countless times it won't start. Can there be a problem with the power button or is it a Windows 8 is problem? Please help.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi,
Try the following.
Disconnect the charger from the laptop.
Remove the battery from the laptop.
Press and hold the Power button for 30 seconds. This will dissipate any residual charge in the laptop.
Reconnect the charger to the laptop and switch it on. Leave the battery out at this stage.
Try to turn on the laptop.
If it turns on allow it to boot all the way to the Windows desktop, let the HDD activity settle down then shut down the laptop in the normal manner.
When it has shutdown completely, switch off the charger and disconnect it from the laptop.
Reinsert the battery.
Reconnect and switch on the charger to the laptop.
Try to start the laptop.
If it starts, allow it to boot all the way to the Windows desktop.
Check the status of the battery charge.
If it is charging allow it to fully charge before switching off the charger and disconnecting it from the laptop.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
After removing battery I followed your steps but screen brightness too low I pressed (Fn+home key) F12 also but brightness is not increasing
의
Please reply laptop is Lenovo G50
의
This post is 3 years old, you should probably make a new post to ask your question. BUT- On an Lenovo Ideapad the brightness control is Fn + Up Arrow. Your brightness changed because your "power plan" setting for battery power is probably set high, and your brightness setting for AC power is probably set low. If you put your battery back it'll go back to your normal settings. If you click the battery icon in your system tray you can edit the power plan settings there
의
댓글 달기
답변을 추가하세요
Pralhad Bengde 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 11,204
