주요 콘텐츠로 건너뛰기
Apple이 제작한 4세대 무선 키보드입니다. 2015년 10월에 출시되었습니다. 모델 A1644.
Magic Keyboard 2 can not connect it via Bluetooth
My Magic Keyboard 2 can not connected via bluetooth, can only connected via usb, it just like dead totally after unplug usb cable.
Before this happened, I were cleaning it, and claped it a little bit, then it can not connected via bluetooth, usb is fine.
I wonder if the wire between battery and board is disconnected or something.
Is anyone knows what is going on ? Do I need to tear it down ?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 3개
Did you clean it with a sanitized wipe? I've seen them cause liquid damage of keyboards.
No, no water inside
I have the same problem, I did not clean the keyboard, but bluetooth connection stops working, only works via USB
댓글 달기
답변 1개
선택된 해법
Hi @kylebing ,
You may have 'bounced' the battery flex cable plug out of the connector on the pcb, when you 'clapped' it.
Here is a link to the ifixit Magic Keyboard Teardown guide.
Scroll down to Step.6 and hold your mouse pointer over the 3rd image to view the connector.
The guide is for the Magic Keyboard but hopefully it will be similar to your keyboard and this will still be of some help to you as you will have to open your keyboard to ascertain what the problem actually is.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks, I have opened it and didn't find the problem is. I think it is caused by the bad battery.
댓글 달기
답변을 추가하세요
Kyle Bing 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 19
지난 30일: 81
전체 시간: 7,799
