주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy S5 Sport는 Sprint 전용으로 출시되었으며 피트니스 애호가를 위해 설계되었습니다.
Replacement screen pops off up top
Hi, I recently replaced my Galaxy S5 screen and the glass keeps popping up on top. I can re-heat the screen and press it down for a few minutes and it stays down. However within the next day it starts popping up. Anyone have any ideas? This is also happening on my ipad.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Either not enough adhesive put on or adhesive being used is too weak.
For the iPad if the adhesive is strong enough, the usual cause is the dents on the iPad frame's metal corners that would need to be bent back in place.
B7000 Glue is usually used in cases like this where the corner keeps pushing up. The glue takes about a day to set in well with tape to hold it in place for it to set.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thanks for replying. I'm going to try this glue out and post back what happens.
The trick is to lift up the screen (on the weak spots only) just enough to put the B7000 glue in, don't put too much of course. Then apply pressure on it and use something like scotch / sticky tape to hold it down.
Then wait for about 24 hours. Take the tape off and rub off the excess glue.
댓글 달기
답변을 추가하세요
kristian Burns 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 1,102
