주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia Z3 Compact는 2014년 9월에 출시되었습니다.
Vertical artifacts after replacing display
I had a broken digitizer and tried to replace the screen (LCD+digitizer)
So cable connected and tested -> Working
Glue added, cable reconnected and slightly pressed on glue while trying to get that cable to bend the right way. When everything was in place, I tested the display again and found suddenly vertical lines extending from bright (e.g. white) elements shown over the whole height of the display.
This now happened twice to me and I can't figure out, what I may have done wrong.
Any ideas?
Start:
이미지
Kinda invisible:
이미지
After boot
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Double check the connection and the ribbon cable to the LCD itself, it may have become damaged.
My guess is the ribbon cable directly coming from the screen somehow got damaged during installation.
That looks like ribbon cable damage / bad connection.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Visually inspected but nothing found there. Very strange
의
댓글 달기
답변을 추가하세요
Alex Grund 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 18
전체 시간: 522
