주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2008년에 출시된 ThinkPad입니다. 이 노트북은 저렴한 가격이 필요하지만 주요 기능을 포기할 수 없는 소규모 비즈니스 시장을 겨냥하여 제작되었습니다.
Supervisor Password Thinkpad SL500
Hi there,
I have a Thinkpad SL500, with a supervisor Password, which I do not know. Does anyone have a clue how I get rid of it. As far as I have read, theres no eeprom on this motherboard which I could short to get rid of it. There is no power on or Harddisk password inserted. Removing the bios battery does not help either now it just ask every startup to correct time and date.
Greets Simon
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
My SL 500 too is lock and Iam experiencing the same problem
의 공유
댓글 달기
답변 2개
가장 유용한 답변
You'll find a couple of liks to recovery password generators at the bottom of this page:
https://therestartproject.org/wiki/UEFI_...
But according to the Service Manual there is no procedure for resetting the Supervisor Password. You have to replace the motherboard. If you can find and replace the BIOS chip that might be a last resort solution but you’d almost certainly have to source one from another laptop of the same model, in which case you’d be better off swapping the entire motherboard.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Lenovo is not suported, I have an error code, but it is a code you can lookup in the manual of the SL500.
의 공유
Also cmospwd does not work
의 공유
댓글 달기
Probably not the answer your looking for but if you have a heatgun/good soldering skills you could try replacing the bios chip: https://www.ebay.com/itm/BIOS-CHIP-LENOV...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I would rather perfer a solution which does not include replacing parts on the mothermoard. Although if there is a solution like with most other ThinkPads where there is to analize a Signal or short some contacts this would be ok.
의 공유
댓글 달기
답변을 추가하세요
Siki 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 23
전체 시간: 1,105
