주요 콘텐츠로 건너뛰기
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
299 질문 전체 보기
What fuse is for the Cigarette lighter
What fuse is for the cig lighter
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 4개
@michmadman6969 what exact year is your Pickup
Its a 1991 chevrolet gmt 400I
2005 dodge caravan i need to know wut kind of fues do i get for the car lighter
88 chevy s10 pick up the cig light doesnt work what and where do i change the fuse
댓글 달기
답변 4개
가장 유용한 답변
@michmadman6969 should be part of the Convenience Center (fuse box interior left side of dash). According to the wiring manual for your model it is marked as CTSY
해당 답변은 도움이 되었습니까?
점수 5
댓글 달기
10 amp fuse, this will be found if you check the fuse in the cab not under hood and check for sure and read the diagram to check which to pull out and if you cant read google that $@$* too
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
It's a 10 Amp, I have a 20 Amp in mine. And there should be another Fuse panel, when you open the drivers side dash board a little panel which got me too, all your other fuses are there.
Found out the Hard way $$$$
15amp fuses should work. If It does not, look on the side.
댓글 달기
Hi @allenrhayes
Check fuse #53 engine bay fuse box. It's the one with an image of a smoking cigarette and 12V marked underneath it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hello John,
The fuse is usually labelled as Cigarette Lighter, The fuse number cannot be given as you did not include a Year or model # in your question. The fuse block is usually located inside the cab on the drivers side however.
Good Luck,
Rich Lilja
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Its a 1991 chevrolet gmt 400I. It isn't marked in the fuse panel. Was told the radio fuse but the radio works fine
it is a 2010 chevy silverado 1500
댓글 달기
귀하의 답변을 추가하세요
John Ladd 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 53
30일 전: 224
전체 시간: 19,945
