Accidentally pulled off Coaxial Connector on board
Title says it all. Was wondering if I can solder it back on, or there is a trace I have to glue down. Or if neither will work
Update (03/16/2018)
좋은 질문입니까?
좋은 질문입니까?
@snakes202 you need to solder this back on. The pins in the North and South direction on your board (picture one) need that connected to carry the signal
이 답변이 도움이 되었나요?
Is that all it is? It looked as if I had damaged the board when it ripped off, meaning something other than the data pins and ground were connected.
@snakes202 hard to see but you may have lost the solder pad on the "north" connector. A clearer /zoomed image might confirm this. Ultimately, yes that is all it is.
I will attempt a sharper picture later. Thanks
If on pcb pads is still in place then flux it and drag solder it or shield the plastic part up and with hot air rework station.
And if you are not that lucky, then you will need microscope and lots of patience. Or send me if you located in uk and ill have a look at it free of charge. Just you funding postages both ways ;)
이 답변이 도움이 되었나요?
Assuming I can not fix it, what would be that cost for you to fix this? A replacement board only costs $50.
free of charge, thats easy repair, you will need just to cover postage expenses both ways
Jacob, have a look how much it would cost you postage to London se14 6qp and if its cheaper then replacement board, let me know... same day as i will receive it ill post it back to you.
Hi, I am sorry for the late reply. I really just need this fixed, and I am not wanting to purchase and experiment in learning a hot air rework station right now. I would like to send the board to you. I appreciate your generosity, but I would like to pay or go through some medium (Like PayPal) for assurance purposes (this is not my board). Please let me know, thank you.
Thats fine paypal is good enough. Email me iggy.gedgaudas@gmail.com and we can sort it out
지난 24시간: 1
지난 7일: 8
지난 30일: 32
전체 시간: 347
댓글 2개
Jacob, try to post a very sharp and high resolution photo of the board, focusing on the position of the pulled part.
adam 의
This is unfortunately the best I can do.
[deleted] 의
