주요 콘텐츠로 건너뛰기
Repair guides and support for Panasonic's Viera line of televisions.
417 질문 전체 보기
Panasonic TH-42PX75U does not see the horizontal top image
Panasonic TH-42PX75U does not see the horizontal top image. The bottom horizontal image is seen. It has sound. The SU-BOARD TXNSU1HNTU (TNPA4184) may be damaged. This has repair or it will be another area of ​​the tv.
With the TV on I loosen the tapes of the SU1; SU2; SU3; SU4 and horizontally in each of them when moving them out small lines of horizontal colors.
Now clean all the connectors. Thank you and awaiting your response
Actualización (20/03/18)
I want to place an image that shows that half of the top horizontal screen of the TV screen is not displayed. That is the fault. Now check the continuity of the SHIPs of the SU-BOARD TXNSU1HNTU card (TNPA4184) from the SU1; SU2; SU3; SU4 and all are approx. in 8. It will be some component of the SC-BOARD stage.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
@panasonic42 do you get any blink code from your power LED?
댓글 달기
답변 1개
가장 유용한 답변
@panasonic42 you are not telling us if you get any blink code from your power LED. Yes the SU would be the prime suspect since it is responsible for the scanning of the upper half. Post an image of what your board looks like and what your screen display. That way we can see what you see. Use this guide 기존 질문에 이미지 추가하기 for that.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Guerra 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 6
전체 시간: 1,338
