주요 콘텐츠로 건너뛰기
1.8 또는 2 GHz G5 프로세서
101 질문 전체 보기
How do I install new bluetooth antenna
I have a new bluetooth board and that is easy to install but they unfortunately did not install the antenna at the factory?? So how do I install a new antenna (which can be purchased easily on e-bay) or more precisely where do I route the antenna and where do I attach the other end?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
The bluetooth antenna is probably hiding in the corner. Here's the installation guide: iMac G5 20" Model A1076 Bluetooth board Replacement
See step 4 and look in the corner to the lower left of the card, it may be tucked under.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
Kevin,
Every 20-inch iMac G5 I've been in has already had the cable. Did you pull out the power supply to make sure it wasn't tucked away somewhere it shouldn't be? Do a double take before trying to follow these instructions:
http://www.appleselfrepair.info/imac-g5-...
I didn't see a guide for this on iFixit but found that guide via google.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Kevin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 1,739
