주요 콘텐츠로 건너뛰기
iMac G5 20" Model A1076 Bluetooth board Replacement
Walter Galan
Walter Galan3 다른 기여자
최종 수정일 April 25, 2024
예상시간 없음
조정
Regain Bluetooth functionality by replacing the Bluetooth board.
필요한 것
부품
도구
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. iMac G5 20" Model A1076 Bluetooth board Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
    • Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 20" Model A1076 Bluetooth board Replacement: 2 단계, 이미지 2개 중 1개 iMac G5 20" Model A1076 Bluetooth board Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the rear panel slightly near the bottom of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
  3. iMac G5 20" Model A1076 Bluetooth board Replacement, Bluetooth board: 3 단계, 이미지 1개 중 1개
    • Remove the two 5.5 mm T6 Torx screws securing the Bluetooth board to the logic board.
  4. iMac G5 20" Model A1076 Bluetooth board Replacement: 4 단계, 이미지 2개 중 1개 iMac G5 20" Model A1076 Bluetooth board Replacement: 4 단계, 이미지 2개 중 2개
    • Bend a paper clip into a hook and use it to pull the Bluetooth board up off its socket on the logic board.
  5. iMac G5 20" Model A1076 Bluetooth board Replacement: 5 단계, 이미지 1개 중 1개
    • Use a spudger to pry the Bluetooth antenna connector up off the Bluetooth board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Walter Galan
701,268 평판
안내서 1,203개를 작성함
댓글 한 개
Greetings Walter Galan, I would like to know if I can install this iMac G5 20" Model A1076 Bluetooth board into my iMac 21 system, it say’s that no wireless is installed.
Please Advise!
Thank You In Advance & Have A Good One!!!.
R.Askew
Randy Askew - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 13
전체 시간: 10,171
