주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Volkswagen Group B5 플랫폼을 기반으로 한 완전히 새로운 Passat가 1998년 북미에서 출시되었습니다.
Car is hard starting
My 2001 Volkswagen Passat 1.8t is hard starting when hot or cold and I have to crank over the engine and turn the key off and try again and again before it will start. When it does start it usually idles really low until it finally catches up to normal.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
This question was migrated from https://meta.ifixit.com/Answers.
댓글 달기
답변 2개
Even though it does sound a lot like a Fuel pump/fuel pressure issue. Get your car scanned just in case. Fuel pump won't throw a code though.
When you have the codes and aren't sure, post back here.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Air flow and throttle show a short circuit .wiring okay
댓글 달기
check your fuel pump in case fuel is not pumping. In case, it's not fuel pump, check the fuel filter if its not that then it is starting sensor. these are the three likely suggestions for the hard starting in VW passat.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Stephen Ryan Bearden Madison E 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 1,726
