주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Beats Solo 2 Wireless 헤드폰은 Beats Solo 2의 무선 버전입니다. 2014년에 출시되었습니다. 모델 번호: MHNG2AM/A.
How to clean/remove smell?
Something seems to have found its way into my headphones that has caused them so smell quite strong, and I'm not sure how to go about cleaning them in a way that can remove it.
The smell seems to be coming from where the speakers themselves are, so I'm really at a loss... It's nothing I can see, there's no discoloration, so it must have been some sort of liquid but everything seems to still be okay aside from their new smell.
(Think REALLY bad cologne)
Any suggestions/instructions?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개:
Hi @danieljperagine maybe get a plastic container with lid, put the headphone inside with maybe a cloth or unused sock filled with some Charcoal Briquettes .... and close the lid, hopefully the smell will be absorbed.
의
Hey Augustine, thank you for the suggestion! You think maybe a lock seal tupperware, perhaps? I'll have to give that a shot. :)
의
Hi @danieljperagine , yep lock seal tupperware or equivalent, as long can seal and put your headphone inside, hopefully those charcoal will absorb those bad smell.
의
So the rice didn't work... It was a good idea, though. Thanks anyway. Gonna try the alcohol solution next... Wish me luck!
의
댓글 달기
답변 4개
Hello Daniel,
I can think of 2 possible options if the charcoal doesn't work.
1. Place the headphones in a bag of rice.
2. Worst case, is to place the headphones into a container of isopropyl alcohol. Let sit in that for about 1/2 hour, remove and air dry it will kill any bacteria causing the smell. Make sure the headphones are completely dry before using. The alcohol will dry pretty quickly, you just don't want to damage the speakers while they are wet.
Good Luck!
Rich lilja
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thank you! I'll give all the ideas a try to see, but in regards to the second option you suggested ... will the alcohol not damage the electronics/leather/plastic?
의
댓글 달기
Hi Daniel, i’m just curious, did the alcohol work? did the leather get damaged at all? I’m dealing with the same situation and nothing seems to be working.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I’ve had these problems too the way I get rid of the smell of the headphones is charcoal and seal it in a plastic container. and after that I put the headphones outside and expose it to the sun
이 답변이 도움이 되었나요?
점수 0
댓글 달기
dont shower for a month, your body odour will over power your headphone smell. And ur welcome. Hopefully this helps you cope with the smell. Thank you and no problem and have a great day.
이 답변이 도움이 되었나요?
점수 -1
댓글 1개:
Hoped this was a helpful comment, was disappointed it was not. Thanks for nothing you wet paper towel.
의
댓글 달기
답변을 추가하세요
Daniel Peragine 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 28
전체 시간: 27,701
