Error!please plug out charger
Unfortunately system UI has stopped
좋은 질문입니까?
Usually either the data on the system UI app needs to be wiped, firmware reflashed on phone again or factory reset via recovery menu which will wipe wipe all data on your phone.
이 답변이 도움이 되었나요?
No this most be from your charging port try to repair your charge port it it's isn't change the problem the check your phone battery connection or change new battery
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 15
지난 30일: 31
전체 시간: 4,379
댓글 1개
I changed the charging port, changed the charging board and even changed the battery, it was still saying error please plug out
Takeover Academy TV 의
