주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
Touch id Not working on my iPhone 7
So just the other day, I subconsciously just started using my pass code more to unlock my phone, I hadn't realized it until now, but my touch id isn't being accepted anymore.
So I deleted my finger prints, and then added new ones on. It worked for an hour or so and now It just doesn't take anymore. It's denying my fingerprint either, It just does nothing.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
댓글 1개
Have you had your screen replaced before this happened?
댓글 달기
답변 5개
선택된 답변
When you boot the device, does it give you an error message saying that there is no TouchID? If it does, then the TouchID sensor in the home button is damaged.
If it doesn't, then the problem may be software related. I would try a hard reset (Lock/DownVol buttons for ~10 secs). If that doesn't work, do an iOs update if available and eventually, try a full backup/DFU restore to see if that helps.
If none of that works or you get an error message, then you will need to take your phone to an Apple Store for a new TouchID sensor. Only they can program a new button.
해당 답변은 도움이 되었습니까?
점수 5
댓글 3개:
@oldturkey03 Oh the irony...even their questions were super upvoted ;>).
@refectio yes looks like a major intervention is needed for that group.
In 2023, Apple will not fix anything except the battery and the screen on the iPhone 7 Plus, they will just replace the device for $349.
댓글 달기
Don’t try to repair this.
Only Apple can fully repair Touch ID without worrying about it being ruined. If you need to ask how to repair this, you don’t have the skills and tools to repair it and WILL ruin your phone.
Just go to Apple, I hate to say this, but they have almost absolute monopoly on Touch ID repairs.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
If it is faulty equipment or software Apple will fix it for free. If it is something they determine you did they will give you a route before repair.
댓글 달기
Reboot your iPhone or iPad. Go back to Touch ID & Passcode in Settings and turn iTunes & App Store back on. Tap on Add a Fingerprint to add another fingerprint
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
May be they have changed. I will look into this and get back to you with new method to resolve your problem
댓글 달기
I would start a repair with Apple. Touch ID is one of those things you shouldn't internally mess with. If you really want to, REWA Technology has videos, but it requires soldering under a microscope and risking your home button. In my opinion, I would just call Apple and get something set up.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Try Setting>> General >> Reset>>Reset All Setting
if did’t work ? just go to Apple Store, they are the only ones that can help with all your TouchID Issues.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ron Bronwick 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 67
전체 시간: 49,643
