주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PS one 또는 PSOne으로도 알려진 이 기기는 2000년에 출시된 오리지널 PlayStation의 슬림 버전입니다.
MY PSOne won't read discs
Recently, I decided to go retro and bought an old PSOne console with the LCD screen component that goes on top. The screen works fine but the console itself is having some problems. I tried to play a disc and at first, it runs then it gets to the Sony logo screen before it resets and starts the loading process again. The console will keep doing this unless you turn it off. At first I thought it was the game disc so I inserted a CD and it did the same thing. I'm still relatively new to all this and I'm not sure if it's either the laser lens or the spindle but I don't hear any scratching or loose parts inside the console. Anyone have any ideas as to what it could be?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 5개
Hi @razor87 , you mean CD, I mean audio cd?
and they are not able to play? anyway parts for this slim lens is also hard to find in market now.
의
Yeah, I meant audio CDs.
의
Hi, I have a PSOne that is not reading discs either. It starts to spin and then stops and just goes to the memory card / cd player screen. I have tried cleaning the lens with isopropyl alcohol (which worked on a PS2 that I had previously) but I am still having the same trouble. Can anyone help?
의
my PSOne starts reading discs but then it stops and my lens starting is buzzing, but when i touch it buzzing stops, and discs cant be readed like that
의
me too I continue to have this random problem
의
댓글 달기
답변 7개
가장 유용한 답변
A common issue that causes the PSOne to not read discs is C705 (a 0.47uF 50v capacitor) going bad. Try checking/replacing this capacitor before you spend a bunch of time messing about trying to adjust the potentiometer for the CD drive’s laser.
이 답변이 도움이 되었나요?
점수 8
댓글 1개:
댓글 달기
I’ve found out that a 4 times out of 5 it tends to be a motherboard issue, so you might as well buy a new PSone because they normally cost just as much the motherboards on eBay. Sorry!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
You will need to either provide to us or do a little research on the specific PS1 revision you have. Lasers and drives now adays are plentiful and cheap on Ebay.
https://www.ebay.com/sch/i.html?_odkw=pl...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I'm not 100% certain which PS1 revision it is but what I can tell you is that it's the PSOne slim remodel that came after the original PSX model. Whenever I put in a game disc, the console starts up, the playstation logo appears and then it stops spinning only to restart the process again. When I do this with an audio CD, it proceeds to take me to the menu that lets you play music but whenever you try to listen to a track, it just repeats the process like with a game disc. I'm hoping that it's the lens and that it only requires a cleaning but I'm not sure.
의
댓글 달기
is the system getting enough volts to completely run it? i had that problem with one i got but as soon as it got the right amount of voltage it worked fine.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
How did you provide the right amount of voltage. What component was problematic?
의
댓글 달기
My disc won spinning too, iv done adjusting lens optic bias and volt, its didnt run anyway… the motor of cd still sleep, but the lens working normaly,
itry to connect the 1,5v battery to the motor(dynamo) its working, but when inout it back as default, the motor still sleep…
i try many things and nothing!!!
should i wasting my money to buy new optic drive set? Or i should smack this thing
이 답변이 도움이 되었나요?
점수 0
댓글 달기
You have a faulty laser
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Based on the information provided, there are a few possible causes for your PSOne console not reading discs:
  1. Capacitor Issue: As mentioned by electro homunculus, a common issue that can prevent the PSOne from reading discs is a faulty capacitor, specifically C705 (a 0.47uF 50v capacitor). This capacitor can go bad over time, causing the disc read errors you are experiencing. Checking and replacing this capacitor might solve the problem.
  2. Motherboard Issue: Anthony Roy suggests that the problem may be related to the motherboard. In some cases, motherboard issues can affect the disc reading functionality. If the motherboard is indeed the cause, it may be more cost-effective to consider purchasing a new PSOne console.
  3. Laser Lens Problem: S W and Akakandbk mention the possibility of a faulty laser lens. The laser lens is responsible for reading the data on the discs. If the lens is dirty or worn out, it may struggle to read the discs properly. Cleaning the lens with a lens cleaning kit or replacing the laser assembly might help resolve the issue.
  4. Power Supply: Kendall Morarity suggests ensuring that the console is receiving sufficient voltage to operate properly. Insufficient voltage can cause various malfunctions, including problems with disc reading. Checking the power supply and ensuring it is providing the correct voltage might be necessary.
It's worth noting that troubleshooting and repairing gaming consoles can be complex and requires some technical expertise. If you are not familiar with console repair or feel unsure about attempting these fixes on your own, it is advisable to seek assistance from a professional repair service or someone experienced in console repairs. They can accurately diagnose the issue and provide the necessary repairs or replacements to get your PSOne back in working condition.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
wow this SCREAMS chatgpt
의
댓글 달기
답변을 추가하세요
Ramon Galvan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 35
지난 30일: 141
전체 시간: 22,231
