주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Centura는 미국 전용 슬레이트 형태의 Android 기기로, Tracfone MVNO 네트워크용으로 2013년 5월 Samsung에서 출시되었습니다. 모델 번호 SCH-738C로 식별할 수 있습니다.
brand new cannot get screen display
just bought cannot get screen display
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
Hi Tami,
first I would make sure you have given the phone a good charge. Next, try to turn the phone on by holding down the lock button on the side of the device. If this is not working, try following the battery replacement guide until you get to the step where you remove the battery. Once you have removed the battery, put it back into place and attempt to turn the phone on again.
If it is still not working, and there are no lights/sounds that occur when you try to power on the device, the problem is likely due to a bad battery or charger. You should try a different charger and if that doesn't work, then you should order a replacement battery and follow the battery replacement guide, or get in contact with whoever you purchased the phone from.
If there are sounds that play or lights that illuminate when attempting to power on the device, but nothing on the screen lights up, then the problem is likely due to a bad connection to the screen, or a bad screen itself. You should try following the screen replacement guide to the point where you take the screen out, then follow the steps in reverse to reinstall the screen, taking care to make sure all connections are tight and secure.
Try powering on the device once more, and if there are lights and sounds, but nothing displays on the screen, then you should order a replacement screen or get in contact with whoever you purchased the phone from.
If you have any other questions, don't hesitate to ask.
Sincerely,
Austin Erickson
Samsung Galaxy Centura 배터리 이미지
안내서
Samsung Galaxy Centura 배터리 교체
난이도:
쉬움
5 minutes
Samsung Galaxy Centura 스크린 이미지
안내서
Samsung Galaxy Centura 스크린 교체
난이도:
조정
5 minutes
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I had the same problem. Solution is to remove the battery and hold the power with the battery removed. Wait 10 seconds holding it down and re insert the battery. Now It should turn on.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Tami Mcardle 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 352
