주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Flip 4 휴대용 스피커. 2017년 CES 혁신상을 수상한 IPX7 등급 방수 블루투스 듀얼 스피커입니다.
Not charging or turning on
My JBL speaker has been working fine and now nothing lights up even when it’s plugged in. I’ve used 3 diffrent cables to try and charge it with they don’t make a difference. Nothing has worked and it makes me sad. I’ve tried resetting it and again nothing happened, so I don’t know what to do.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 4개
i fixed it,
you have to put
pressure on the flat cable that is connected with the "power button/LED/ JBL Connect Chip". Then you have to put a cable back in the usb chip
after that it should work again
의
And how do you do that?
의
all of you are wrong!!!,
Did you check the 5v on the usb type v8 line?
Did you check the 5v on the usb board?
Did you check the 5v get to IC charging?
Did you check the 5v get to Batery?
Did you check the 3.3v & 2.7v & 1.2v to the PMIC?
의
how do i check all these? is there a kind of tutorial?
의
댓글 달기
답변 1개
가장 유용한 답변
If your JBL Flip 4 speaker refuses to turn on, see the JBL Flip 4 Won’t Turn On problem page for possible causes and solutions.
If your JBL Flip 4 speaker will not charge or won’t hold a charge, see the JBL Flip 4 Will Not Charge Or Won’t Hold a Charge problem page for possible causes and solutions.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Abigail J Rhea 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 18
전체 시간: 3,802
